Lets go jungle error 10
Тема в разделе "Видеосимуляторы", создана пользователем M27C4001, 11 ноя 2017.
  1. M27C4001
    M27C4001 Участник
    Еще по 11 CMOS скинуть советуют здесь
    https://forum.arcadeotaku.com/viewtopic.php?t=22507
    I got your PM, put i prefer to answer you here.
    If the led on the baseboard is always orange, and dont go to green blinking, probably the Baseboard is dead.
    Try the folowing:
    1) Remove both batterys from the Motherboard and from the baseboard.
    2) Change jumper switch near to the battery from 1-2 to 2-3 to do a cmos reset.
    3) boot lindbergh until you got a cmos error, defaults loaded.
    4)Shut down lindbergh and put back batterys.
    5) Boot lindbergh again until you got a cmos error, defaults loaded.
    6) Power off lindbergh and put back jumper to 1-2.
    Now reboot and watch the internal led on the baseboard, if the led is always orange, try to change the Baseboard, to another PCI slot on the lindbergh, for example, you can exchange audio card and Baseboard card position.
    If after all this tests, the Baseboard led is still orange, 100% sure that the Baseboard is dead, 25% of the time is a corrupted flash memory and 75% of the time, the Motorola PowerPC is dead, or needs reballing.
    If you can get to the test menu screen with the baseboard inserted, you can go to the system information and see if the baseboard appears there, must be detected if the baseboard is correct.
    Without the baseboard inseted on the lindbergh you should be able to get to the Lindbergh logo screen and then you should be able to use Test Buttons there.
  2. arlo
    arlo Новичок
  3. M27C4001
    M27C4001 Участник
    Вопрос решен.
    Проблема в умершей PCI baseboard.
    Она стала светиться оранжевым потом зеленым потом опять оранжевым и вконце зеленым.
    Поменял з HODIV плату рабочую- аппарат работает.
    Буду заказывать плату.
  4. M27C4001
    M27C4001 Участник
    Я так думаю что ничего нового не вылезет, кроме платы
  5. myxamor
    Не дёшево они стоят...
  6. M27C4001
    M27C4001 Участник
    Ну пусть покупают...я все протестил.
    Один человек написал на форуме Сега что в етих платах 25% дохнет память и 75% проц, но реболить его это дорого.
    Замена лучше будет
  7. myxamor
    Ну тогда пишите, есть они... В личку
  8. vododohov
    vododohov Новичок
    OEM
    разбери пистолеты,видимо кабель перетерло,и замыкает на корпус
  9. vododohov
    vododohov Новичок
    OEM
    1000% дело в этом
  10. M27C4001
    M27C4001 Участник
    Все запустилось и работает на аналогичной плате. Проблема в плате
  11. myxamor
    Откуда на "Лэц го Джангл" провода для пистолетов? Если там стоят стационарные пулеметы???
    Да и потом, если бы и был кабель, и перетерся, то прежде всего не работала бы совсем другая плата...
    M27C4001 нравится это.
  12. umidbek84
    umidbek84 Новичок
    Добрый день помогите пожалуйста у меня тоже такой агрегат но уже сколько месяцев он не работает причина видео карта. Не могу поменять потому он залочён, хочу спросить можно ли игру пересадить на другую плату или есть другой способ починить игру. Спасибо
  13. muk
    К Мухамору в гости. Поможет.
  14. -Vlad
    -Vlad Участник
    Образ на DVD запиши и игру все равно переустанови.
    И в запасе все образы надо иметь всегда.
